"Frankenstein" 1st Build // Earthwing SuperGlider Longboard // Unbranded "Esk8 Market" 190kv 63mm // 10s LiPo (5 x 2s 5000mah 60C) // Abec Clones (90mm) // VESC
Be advised it could take up to 4 weeks for delivery. Although you might get lucky and get if sooner. Just don’t worry, it will come and will be worth the wait.
All the better to order sooner! XD
Okay. I’ve updated the main page with all the items. All I need to order now is the PCB, wiring for the batteries and charger for the battery’s.
Oh, and a solder kit.
Blew my budget out the water, but I’m excited to get to work!
https://www.ebay.com/itm/222029867724
Out of Stock
Weller D550PK 120-volt 260/200-watt Professional Soldering Gun Kit
https://www.amazon.com/dp/B00002N7S1/ref=cm_sw_r_cp_api_B377ybWQKSZJK
http://m.ebay.com/itm/Universal-Charger-42V-2A-Adapter-For-Hoverboard-Smart-Balance-Scooter-Wheel-US-/332136054967?hash=item4d54da00b7%3Ag%3ANhgAAOSwfVpYroIn&_trkparms=pageci%3A00f1a1be-2074-11e7-b663-74dbd18082c3%7Cparentrq%3A687f51c215b0a2a3986fe2cbfffdfb50%7Ciid%3A3
Better yet 300watt Weller D650 Industrial Soldering Gun Great for soldering heavy wires
https://www.amazon.com/dp/B000JEGEC0/ref=cm_sw_r_cp_api_j977ybP159HK1
DROK DC8-63V 12V/24V/36V/48V LCD Lead-acid Battery Capacity Tester Gauge Panel Battery Statue Indicator Monitor Electric Quantity Detector Reader
https://www.amazon.com/dp/B00VUUKIMY/ref=cm_sw_r_cp_apip_Xp789UyUARj4e
Back to work, I’ll post some more stuff later
uxcell 50pcs 6x6x4.3mm Momentary Tactile Tact Switch 4 Pin DIP Through-Hole
https://www.amazon.com/dp/B0090VQK7C/ref=cm_sw_r_cp_api_m787ybQ7G9A0Z
Racers Edge 1502 Wide Servo Tape, 1 1/2" Get a couple rolls
https://www.amazon.com/dp/B003U1NWJM/ref=cm_sw_r_cp_apip_WVqclAIUA9Jpz
Do I buy the Capacity Meter or the Volt/AMP Capacity Meter?
Wasted money counter ?
Do explain?
Capacity meter and modify it to display voltage or just get a voltage meter.
Looking at your old post with your Battery Build. I’ll need 5 of these correct? This will allow me to individual test each battery and allow for easy replacement.
Yes those are very handy for extending the balance wires. The servo tape works well for mounting the batteries and electronics to the deck. For the Vesc mounting I used a Lipo battery tray with Velcro buckle straps
Some other how to info for my build is in this other thread. At the time of this project, I was anti Lipo but after experiencing both worlds, I reverted back to Lipos.
Shouldnt I get a smaller, electrical soldering iron?
Also, in your battery build, you used regular rosin core solder to combine the battery packs correct?
