Hello Everyone,
Glad to be with you guys to discuss technical problems of electric skateboard, thank you all for your support and help for more than two years. Now we made wide range of improvement according to your suggestions, and sincerely invite you to review it free of charge .
Please contact us ([email protected] / [email protected])
Here is our latest product picture.It seems to be no improvements on the picture, let’s see what details we have done.
1.Replaceable PU wheels
We upgraded the wheels from 83mm to 92 mm, the thickness of the PU wheel increased 9 mm; and the material upgraded from HR85A to SHR 80AA, this improvement is that the wheel is more wear-resisting, increased ride stability, more comfortable.
2.Remote
Although the appearance is the same as before, the PCB inside is completely new design, we added vibration tips on it, so that you can master the status of the skateboard better. The brand new optimized control code and the remote distance upgraded from 10M to 40M, which makes it more effective.
3.Circuit board
The most core part of this update is the whole seal-able circuit board inside an aluminum alloy base, which makes the installation and maintenance more convenient, and avoid the interference of the external environment to effect its performance. This is only the appearance, the new circuit board use sine-wave, dual mode control (can be used with/without hall sensor), linear soft brake, fireproof protection circuit design, 12 safety protections,etc., those functions make the circuit board much better than the previous generation.
4.Battery
There is no change in appearance, but the BMS are new designed. We added different charge-discharge ports inside, the output current is more stable, the regenerative braking system is much effective and safer.
It hard to tell you what comprehensive upgrade we did through these sentences, sincerely welcome skateboard fans to contact us, we will choose some of them to test our products free of charge. We are looking forward for your joining.
Landwheel
