I would highly recommend ordering an extra DRV8302 and like five 5V TVS diodes.
Something as trivial as a (SINGLE) bent pin can really ruin your day, had to throw out a DRV8302 because of that DXXX.
I would also recommend removing the DRV8302 and 5V TVS diode and performing electrical checks to make sure there aren’t any other components that need to be replaced.
So using the remaining vesc reprogrammed to be master with the recommendations from you guys above, I did a no-load throttle test, and got several blinks of the red light that triggered a motor cutoff when punching the acceleration (didn’t happen when slowly increasing acceleration). It didn’t fry the vesc, so I was able to read faults off the DRV and it gave these:
The following faults were registered since start:
Fault : FAULT_CODE_ABS_OVER_CURRENT
Current : 19.6
Current filtered : 33.3
Voltage : 48.20
Duty : 0.671
RPM : 39680.3
Tacho : 20488
Cycles running : 3768
TIM duty : 4051
TIM val samp : 2025
TIM current samp : 5044
TIM top : 6037
Comm step : 2
Temperature : 29.02
Current : 22.6
Current filtered : 30.3
Voltage : 48.50
Duty : 0.579
RPM : 34449.4
Tacho : 26527
Cycles running : 3203
TIM duty : 3983
TIM val samp : 1991
TIM current samp : 5428
TIM top : 6874
Comm step : 5
Temperature : 29.02
Current : 27.0
Current filtered : 31.8
Voltage : 48.52
Duty : 0.463
RPM : 25979.0
Tacho : 28358
Cycles running : 1924
TIM duty : 3863
TIM val samp : 1931
TIM current samp : 6102
TIM top : 8342
Comm step : 6
Temperature : 29.18
Current : 25.0
Current filtered : 32.2
Voltage : 48.47
Duty : 0.458
RPM : 25895.3
Tacho : 29660
Cycles running : 1913
TIM duty : 3857
TIM val samp : 1928
TIM current samp : 6141
TIM top : 8425
Comm step : 6
Temperature : 29.07
Looks like something lose.
Check all connections and have a look if there bad solder joins on the pcb etc.
People had this issues when the caps where lose etc.
I had this fault for a while and than the drv popped…
That makes sense as it is an over current fault.
So it appears only when the vesc sees too high values for the current, what could be while accelerating (but shouldn’t happen on the bench how it is in your case…)
Why does the vesc shutdown at 30A, instead of making that the artifical ceiling of current draw? If I want to floor it/do the hardest acceleration possible while staying under or at 30A, I’m confused why it shuts off vs holding a 30A ceiling.
Can anyone help me with my vesc settings? I have dual 6374 190KV 3300w motors with a 10s battery. The vesc is rated for 150A continuous and 300A surge. I’m getting almost no torque at all with the default settings, (I can stop them in mid spin with my hand)
Maybe you want to split this up and create a new topic. Post your setup, which battery exactly, which vescs, which motors, which gearing and wheel size.
