Just got some fat rubber tyre from Stormeskate and all fitted in except for the gears section. Mine is a DIY build from DIY Electric skateboard. Looks like I have to machine new ones or anyone has any fabulous ideas. I tried using without belt. Traction drive is not really working at the moment. The gear system is too big with the fat wheels taking all the space. Urgent help needed
Where did the idea for traction drive come from? Is it in the packaging?
You need a pulley, is the wheel the right way around? It’s offset so you need to mount the shallow side inwards. And you need a longer mount to get a belt on there.
Unless traction mounting is something I don’t know about and it works?
Nah was only told the tyre would fit the longboard. Well it didn’t. I tried all means till coming up with this rugged design. Will try again with a right size rubber wheel. That is just double sided tape rolled over and over.
I wouldn’t try to use friction drive. It will be rather inefficient and slip a lot. This is why you should check the compatibility of parts before buying them
