Hi, this is my first build, and I have some questions about how to connect all the different parts together. Here’s the list of my main parts:
Motors: https://www.meepoboard.com/en-ca/products/meepo-donut-hub-motor-kit
Battery: https://www.mboards.co/collections/batteries/products/10s2p-p42a-battery-pack-transparent-series
ESC: https://www.mboards.co/collections/escs/products/dual-hub-motor-esc
My first question is do these parts make sense to use together? Is a part overpowered or underpowered?
Next, I need some advice on how to connect the battery and BMS. The battery has an XT connector which looks like it could go directly to the ESC, but I feel like it should go through the BMS first? What are the two smaller leads coming off the battery? Are they the wires that go to the BMS, while the XT connector goes to the ESC directly?
I found this wiring online that looks like what I would need. Does this look right?
