I have a 12s4p battery that had what looks like a power switch from DIY. After about 10 on/off while setting up the board it would no longer turn off. I replaced it with a vedder anti spark and after more testing and setup (never used while riding) it has failed after about 20 on/off.
Why are these switches failing and what am I doing wrong. Neither was used under riding circumstances just assembly on my bench.
I have the amp limit set to 25 on both VESCs and it went bad on the bench. It never had any riding time so I would assume very little amps would have been through it.
Here is a picture of the vedder and everything looks good.
I built the battery with a Flier switch. ( switch fried which happens sometimes with them) so I sent out an ollin board vedder switch free of charge (all of my batteries come with them as of a while ago) and it fried also.
P.s. I’ve sold about 20 vedder switch battery packs with zero problems and I’ve used them on my personal Killer Trampas which pull immense amps and 12s. So im not sure what the issue is.
The two outer pins are Ground and Positive. Connecting the center pin to Positive turns the switch on, connecting the center pin to Ground turns the switch off. It is possible that your mosfets have failed but it could also be a wiring issue between the switch and toggle.
I doubt the mosfets have failed unless you have a huge bank of capacitors to charge when you power up your system.
If trouble shooting doesn’t correct the issue you can send the switch to our shop and we will fix or replace your switch.
One question, are you toggeling the switch rapidly? That will fry a switch sometimes at 12s, it can cause the switch to heat up.
You also need a crimper and terminals to make your own. An alternative would be to remove the jst header and directly solder the toggle wires to the pcb.
Cool, I will try and send it out today. One of the wires on the toggle switch also broke off, I am assuming from the plugging and unplugging I have been doing to test, I will send that as well and if I could just get a new end put on it would be greatly appreciated.
FYI, my wires got pulled out of the JST connector as well. I only unplugged the switch once
Not a big deal because I was going to replace the switch anyway. Just thought you should be aware. It might be better to solder wires directly to the board and use an inline connector
I don’t recommend pulling the wires to disconnect jst ports. They have a little locking tab and you need to grip the plastic housing when disconnecting ports.
No doubt I think I just did to much fiddling with mine. Is there any solution that would send that out at a right angle instead of straight up? I am a little worried as it sits on top of my battery pack and that is the tallest point of the pack.
