Furthermore I have to change the battery layout, because of 2.5Ah per cell, so in this case I need 6s4p battery pack… That become even more expensive…
Can you give me a approximate budged to make a good price-quality ratio 22.2V 10Ah battery pack ?
I know other cell’s brand, only Samsung is a valid option??
Get 30Q - it is the cheapest one I’d recommend. 25R are a little cheaper but voltage sag is huge with those and as you are running at only 6S the current draw will be higher -> even more voltage sag.
Liion packs are not cheap - if you want cheap you have to stick to Lipos. A liion pack will cost you at least 100€ rather 200€ with all the necessary equipment.
i would also suggest HE4. I’m running a 6s3p with them and while voltage sag is definately there, i can get a good range and tourque out of them. and they are pretty cheap.
I don’t understand people. Basically everyone with knowledge on 18650 cells on this forum agreed that 30Q are the cheapest cells we recommend. Look at discharge curves and you will not want the HE4 cells - especially in a 6S setup.
Look at the comparison on http://lygte-info.dk/review/batteries2012/Common18650comparator.php and set the current to something high like 15A.
Cells can be bought at nkon.nl if you are wondering where to get them. They ship to everywhere in Europe and sell genuine cells.
