looking for a good eauropean website or link for a high kv motor for single drive
Alien power system
honestly mate you dont need high kv. I have the 149 kv motor and my board is plenty fast and quite powerful as a single drive. Dont get too caught up in the numbers. Lower kv usually means higher torque and less heat which means more efficiency
best kv for a 12s 20wh setup?
https://eskating.eu/product-category/motor/
190 Kv is good for a 12S, 170 Kv is also fine, just adjust your gearing accordingly. use a calculator like this one: http://calc.esk8.it/
Then you can plot in your battery cells, your motor Kv and you can check whether you can find pulleys that will adjust to your optimal topspeed
What’s the speed you wanna reach? Battery voltage you want to use and which is your wheel diameter?
how do i know the voltage on a battery? be using 12s so using the calculator thats 44.4v in total. what batterys would you recommend looking to hit about 25/30mph max wheel diameter not sure yet as might be using abecs or might be using the mbs all terrain wheels as be better for bad roads/sidewalks.
looks like ill be using alien motor but not sure what one yet…:
could buy 2 of the alien ones for that?why so exspensive?
not tried these but these seem new to the market, if its of help to you
