Unfortunately only in Australia warehouse, but 50% off. When stacking these, you could do a 12S4P (10Ah) for ~100 bucks!
EDIT: I meant 12S4P if you think of 2500mah a parallel group. Sure, when you count one of these batteries as a parallel, you will get either 6S4P or 12S2P
No. Well I meant that normally you count 2500mah as one Parallel group. You would get a 12S 10Ah battery out of four. But sure if you take 5000mah as one Parallel group, then you are totally right.
No you got me wrong. 2P of these batteries (25Ah=10Ah) is equal to a normal 4P li-ion (42,5Ah=10Ah). This battery 12S 10Ah and 20C discharge rate can output 200A, not 400A.
