I decided to do something different from the usual Badwolf style enclosure: I wanted the controller mounted on my arm. So I made this ugly yet functional prototype.
The trigger is mounted sideways inside the enclosure, and the wire coming out just pulls the trigger. Downside: it no longer has any adjustable braking. No throttle = full brake, which is not as bad as it sounds, but not ideal.
I plan to design and print a proper case for it, but for now it’s at least working better than I expected.
This is an awesome innovation @mattdig nice work! Could you replace the yellow wire with a thin metal rod so that you could fully implement brakes? Or maybe flip the controller to fit on the other side of your wrist, spider-man web-shooter style?
Debating trying to do this with my GT2B remote. But I’d rather have to place my finger in a trigger area versus attached to your finger directly. Attached could result in unexpected reactions as you lose balance momentarily, etc…
It’s surprisingly consistent and hasn’t done anything unexpected yet. The stock spring from the original trigger is a really good weight and it always reacts like I expect it to, even when there’s suddenly random stuff in my way that requires dodging or braking.
