I have used this esc before, and it works great for me. I used it on my first, hevily budgeted build. I am pretty sure it is the same esc as on the meepo board.
Hello, I also think about buying this esc. I am currently using an 80kv 70mm hubmotor and i want to get about 30kmh out of it and on calc.esk8.it it states that the motor can reach that speed with 10s.
So my plan was to use the non-hubmotor esc (because it has no speed limit) with my current hubmotor and a 10s battery. Would that setup work or would i get problems because i am not using the hubmotor esc?
Why should the hubmotor esc not reach 30kmh? Meepo board has the same hubmotor esc and can go like 35kmh. If you go for the brushless motor esc the throttle will be very sensitive. I should just stay with the hubmotor esc, Iām sure you will get a max speed around 35kmh.
I heard that the hubmotor esc is limited to 20kmh
Okay i didnāt know that, thanks
Go for this one: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F302538835504 When you pay the order, donāt forget to mention the voltage 6S/7S or 10S in the message area.
Thatās the one I have and the acceleration and brakes are pretty awful. Honestly if we could figure out a way to make the ramp on the throttle/brakes adjustable this wouldnāt be a bad controller.
Iāve talked to the seller and apparently the escs can be programmed, itās just that they are programmed at the factory and once they leave the factory you canāt change the programming.
If a seller figured out how to order these where you could either change the programming, or just ship them with an acceptable brake and throttle curve, itād be a good esc for budget builds
Itās very linier, brakes and acceleration should be progressive
Iām waiting on belts. When they arrive, Iāll test the single drive and Iāll send a video
I have the Banggood one for hubs if you canāt wait on shipping
No thanks, iām going to buy it on ebay
Did you do the Banggood combo with the $00 hubs and $60 dual hub esc?
Huh? Hubs for free I missed that!
Ha, sorry, $100 hubs.
Hi, Iām glad I found this forum! I recently purchased the dual hub motor ESC and a set of hub motors from Bang Good (see pic). Problem is, the sensor wires from the hub motors are only terminated. They do not have a connector on them so I have no idea what wire goes where! Bang Good is no help with any kind of instructions. Has anyone figured this out yet?? It would be much appreciated! My poor kid is ready to just start trying things - but I have fried too many Lipos to know better!
Dont connect sensor wires it works just fine
Agreed, no need for sensor wires
