I am having an issue where I’m getting “motor detection failed” from ackmaniac ESC-tool during automatic motor detection/configuration. The motor will not spin even though everything appears to be connected properly.
This was after I tried flashing both firmware versions 2.54 and 3.101 to the FOCBOX. I read a thread by ackmaniac about the version 2.54.bin and when I try that one it the ESC-tool doesn’t even seem to connect to the VESC.
@CarlCollins What is Enertion’s policy on bricking a focbox exactly?
And is there a way to easily restore a FocBox from “bad firmware?” If it can be done easily, it may be worth putting together some kind of “FocBox Doctor” package for it.
With the ackmaniac ESC-tool, reload the bootloader.
Then reload 3.101 FW.
now make a quick video of your failing motor detection, explain you battery setup.
You might just be trying to perform a motor detection while outside of your working parameters (ie battery voltage cutoffs out of bounds) or you need to tweak your detection parameters.
I don’t think I bricked it. I’m still able to power it up and connect to it.
I’m gonna try again with firmware version 3.101 when I get home, I was getting confused because the “official” @Ackmaniac thread kept referring to downloading and flashing ackmaniac_2_54.bin.
