13s4p might be the better option for this deck with @Winfly’s compression modules.
Insta-warranty-void for the Unity, isn’t it?
??? 10char
Using it with 13s instead of 12s.
I doubt that 13s would be the reason you blow up a unity…
I mean I found this…
That is the extreme of extreme cases. Running on the upper limits of the hardware comes with that risk. If you are concerned I would just get the warranty and you should be fine. If you can’t blow it up in the year you probably never will.
It’s just the limitation of the deck. They have made use of most of the available space. If you want more you really need to go wider with something like the recurve and run a third channel with some of @Chaka’s vescs - I’m doing this for a 12s5p 4x4 build.
its tricky, but with a support metal plate on top its doable (@ your own risk). The support plate would be fixed, for example, with some solid M6 inserts and quality 10.8 Rated M6 Bolts
I looked at more photos and wonder if this board would accommodate 6 inch pneumatics on TB long trucks?
@bevilacqua any chance of releasing just the nose/tail of the cad so we can make dope community protection/led or such?
I wanna try printing something in 80 shore or higher TPU
Sure, no problem, I dont have acces to 3D sw right now, give me 1-2 days
Excellent, thanks a million
U can try to check this out… they fit perfectly into the nose/tail… I included the STEP files as well
Ahhhh this is cool as well! Maybe we could integrate this as well…
OO where can I get one of those?
It was ment for a defective deck that had a shorter nose. My father ended up gluing some wood noses: (it was the first test deck for the CNC and was pressed with shorter veneers)
It it still looks perfect!
your father is a master at work. small details make the full difference. really impressed.
Totally.
@bevilacqua when’s the kick tail version coming out?
Also, since it’s bound to happen to at least one of us here, can you let us know the size of the torx screws for the top lid, in case we lose one?
