Hello I want to make and DIY lacroix but I want It water resistant so should I top mounted my battery/ESC etc so my question whas how water resistant is the standard enclosure?
Water resistant is not the solution. You want waterproof. Which means even if the enclosure is filled with water, it still works.
Yea that sounds really nice but how does it work?
Mostly “MG Chemicals Silicone Modified Conformal Coating” in 55ml brush-on bottle (multiple coats) – and for heatsinks: “MG Chemicals Acrylic Conformal Coating” in 55ml brush-on bottle (1 coat only)
Wow. If ever a thread was designed for you…
Put your electronics in a ziplock bag and hold it
You are such a troll (AsianBOi)
