I’ve just pulled my portable charger apart and found out the have 18650 cells in them. It was 4 for $25 Aud and I don’t know how to test them to see if they could work for a custom pack if I got more. It was a 5000mAh pack so I’m guessing they are 2500mAh each cell could they work, I want to make sure before I get more of them.
Riona super ginues. On you tube
I guess they are these. With a max discharge current of 2A they are definitly not suitable for an esk8. You would need at least like 10 of them in parallel to have a minium acceptable power for an esk8.
<im
<img src=“https://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/original/3X/f/a/fa269371bcf646b3802819768917829d60c79faa.jpg” Uploading… Uploading…I hope those cells have a higher discharge rate than the mobile charger ones. What battery pack configuration are you aiming for?
I only use sumsung for my board
10 s3p and on my board 10s4p.20amp discharge Cell
The color of Cell tell you what discharge they have.
Never heard of that…
2 min
.im goinhg tô show you
You must be joking…
Its like more capacity less discharge
More discharge less capacity .
The color of the heatshrink doesn’t tell you anything about discharge rate…
Go check i dont no
No?…
why is there more than 1 red lines then?
It is just a ‘‘wrap’’ / decoration / protection cover for the metal cell…
U need to look up the model / name of the cell, to determine its capacity / discharge rate.
How to identify 18650 cell capacity by color?
You just don’t. Look up what is written on the cell and you get your data.
