Have been looking at JST-connectors but there’s a lot of them, anyone who knows what model i need?
I measured the connector on the inside, it’s 4mm in height, 10,7mm width and the pins are 2mm apart.
Hi, did you figure it out how to connect them? I would be interested in knowing which is the pin order on the ESC for the sensor cable. I know you should have 5 cables and it is importat to place correctly the 5v and the ground ones (usally red and black, but I want to be sure). Thx for the help!
Thanks for the information. You said the other three were marked but where you see the order for the green, blue and yellow? If you can post a picture about it would help a lot! Thx
I just kept the same order the 6 pin connector had when switching to 5 pin and kept phase leads in order 1,2,3 left to right and kept the order coming out of the esc , just worked
By the pictures available online I can not read a thing on the ESC. Would you mind to take a picture of the ESC where you can see it? The reason why of that is bacause I need to link the sensor wire to a VESC. Thx
Hi, these are two pictures of the ESC, one where you see the markings and one with the sensor connector from a diyebord-motor (90mm hub motor) plugged in.
