So a couple days ago my board has decided to brake randomly but only one motor so I thought it was bad insulation on the phase wires. I tried starting it up off the ground and one motor would turn the other one was cogging and then sparks flew out of it. I imminently shut it off and pulled the motor apart.
Have you tried sensorless? I had a similar issue with sparks due to an issues somewhere in my sensors but run them sensorless fine
What motors are u using. I’ve just about had enough with flipsky
Ahh they’re some cheap Chinese hubs I’m not actually sure where they’re from - extra second-hand from another member
Ok thanks for the info. Il try running them senseless.
