Hi everyone.
I am building my first electric skateboard. And i want to monitor the temperature of the BMS, VESC and Batteries.
I have bought a Arduino Uno and 3x LM35 sensor.
I have found a stock code to get 1 sensor to work. Now my problem is how to get the other two to work. The sensor are connected to A0, A1, A2. Here is the code
I hope someone can help me
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //Digital pins to which you connect the LCD const int inPin = 0; // A0 is where you connect the sensor void setup() { lcd.begin(16,2); } void loop() { int value = analogRead(inPin); // read the value from the sensor lcd.setCursor(0,1); float millivolts = (value / 1024.0) * 5000; float celsius = millivolts / 10; lcd.clear(); lcd.setCursor(0,0); lcd.print(“BMS”); lcd.setCursor(0,1); lcd.print(celsius); lcd.print(“C”); lcd.setCursor(0,1);
delay(1000); }
