*Help* New builder and much needed advice on parts!
Absolutley… High capacity 1500W 36V 30AH Lithium battery 36V 10S scooter battery Use 3.7V 5.0AH 26650 cells With 50A BMS 42V 3A charger Hows is this?
What the continuous current rating on the battery? Who makes it? I’d be worried about vibration resistance on any battery that’s not specifically designated as being for a skateboard.
Battery Model:36V 30Ah
Nominal Capacity (AH) :30ah
Nominal Voltage (V): 36V
Cell Source Resistance (mΩ) :40mΩ
Cell Specification :3.7V 5.0AH 26650 3C Powerful cell
Cell Combination :6-parallel 10-series
Cell OverCharge Protection Voltage:4.2V/Cell
Cell Overdischarge Protection Voltage:2.75V/cell
Discharge Cutoff Voltage (V) :30 +/- 1V
Charge Cutoff Voltage (V) :42V
Rated Discharge Current (A): 50A
Maximum peak discharge current (A): 150A
Maximum Continuous Discharge Current (A) :50A
Charger mode:CC/CV(Constant Current Constant Voltage)
Standard Charge Current (A) :2A
Charge Time under Standard Charge Current :15h
Max Fast Charge Current (A):5A
Charge Time under Fast Charge Current:6h
Charge Temperature Range :0-45°C
Discharge Temperature Range:-20-65°C
Life cycle:more than 800 cycles
Battery Size :28017070mm
Battery Weight : About 6kgs
This isn’t really that high but it’s not so low you can’t use it. However, the other more important questions all remain…
You don’t want to spend multihundreds on a battery just to have it burn down on the twentieth ride
thats very true
What about a few of these batteries? (4-6 of them?)
Gens ace 5000mAh 11.1V 3S 50C 3 Cell LiPo Battery Pack with XT60 and Deans Plug
Specifications:
  • Minimum Capacity: 5000mAh
  • Configuration: 3S1P / 11.1V / 3Cells
  • Discharge Rate: 50C
  • Max Burst discharge Rate: 100C
  • Net Weight(±20g): 380g
  • Dimensions: 155.3mm x 46.3mm x 24mm (L x W x H)
  • Charge Plug: JST-XHR
  • Discharge Plug: Deans and XT60 plug
Would 4-6 of these give good range?
I would recommend getting an even number of “5S” ones instead of 3S ones
You do want to make sure they are at least 30C, the higher, the better
For such a long-range pack the C rating is slightly less important
I would look at hobbyking lipos if you want to go that route
