I’m looking to build my own electric long-board and I need some advice/help before I go ahead and buy all my parts, fist Id like to know everything I need to build one, second of all… I don’t know the difference between what a VESC, ESC, FOCBOX, Etc.
Here’s what I’m thinking so far:
Trucks:
Caliber Trucks Cal II 50° RKP Longboard Trucks (set of two)
Batteries:
ZIPPY Flightmax 8000mAh 3S1P 30C Lipo Pack with XT90 (5 of them or 6)
Gens ace 5000mAh 11.1V 3S 50C 3 Cell LiPo Battery Pack with XT60 and Deans Plug (OR THESE)
Bushings:
Venom Bushings - High Performance Formula
Wheels:
MBS All-Terrain Longboard Wheels 100mm
Motor mount:
TOURQUE BOARDS BOLT ON MOTOR MOUNT W/ DRIVE WHEEL KIT (x2)
Motors:
Hobbysky 6374 170KV 190KV Brushless Outrunner Belt Motor 8mm /10mm Shaft (Two)
Remote:
Not sure if somone could plug a good remote that would be nice VESC,ESC,FOCBOX:
Don’t know the difference between the three and whats best for the board
That’s all i have so far… do I need anything else and is the parts list good??
P.s If there are any better battery options for long range let me know!!
If all goes well, I’ll create a build topic that people can follow and watch progress!
This inclusion in your list is a very clear example that you my friend need to do a hell of a lot more reading. Its all here just use the search and do your research. Welcome to the forum and good luck with the studying.
Acually, If I’m being honest I know a basis of what a VESC is, Its the brain of the board and controls everything and speed or what not I just dont know the difference between VESC,ESC, and FOCBOX
@ethanfields just fyi, standard builds are 10s and 12s because VESC are rated for 60V max . 12s puts it at 50.4V at full charge. some of use do 13s at 54.6v but when you break, voltage can spike over 4-5V. default overvoltage protection is at 57V, so if you hit 57 it cutoff.
I have hit 58v personally by raising that limit but that’s me. me take risk for POWAAAR . As a beginner, I suggest you go with 10s or 12s.
I would highly recommend 10S (42.0V max, 37V nominal) and definitely not more and probably not less. This means you either need an even number of “5S” lipos or you need a multiple of 5 quantity of “2S” lipo.
If you want 12S instead (I personally don’t recommend this) then you need multiples of 4 times “3S” or multiples of 3 times “4S” or even numbers of “6S”
Also you don’t want to mix and match them. Get them all at the same time from the same place, and all the same kind.
