Hi there community, I am planning to build a 12s8p battery with Sony vt6 Li ion cells to use use focbox and 6374mm 150 kV motors. I am not sure of the amperage of the BMS I should use. Can you please help me out? Thx heaps! and sorry for the noob question which is probably covered somewhere I could not find.
you can run a charge only bms so that the battery isn’t limited.
please do some reading, 39min is not enough
Maybe he read a lot prior to his sign up. Who knows ? +1 on your suggestion, I’m gonna do that as well to save a little $
