I’m trying to determine if three 560uF 63V capacitors on my vesc is sufficient for a 245kv 10s setup? Most of the ones I see these days have 680uF or higher.
I know this motor/battery setup isn’t ideal for the vesc, but it’s what I’ve decided to do for my first build. This was the only part that arrived “not as described” and I do have the option to return it if necessary. It also came with 14 awg wire, but I can always replace it with 10 awg. Thanks in advance for your help.
