Hi
It is my first build and here is my situation.
I have this motor pully: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F322328974649
And am using a 36T wheel pully w my 90mm flywheels. Currently I have a 265-5M belt that is 15mm wide, but it is just a little too small. What belt size do I need with these parts?
Thanks!
I just went and filled it out but it didn’t tell me the length. It gave me pitch diameter for each but not length
What motor mount are you using?
Edit: you need the teeth count for both pulleys and the center to center distance
Boardnamics caliber 2 mount for 50mm sk3 motor. Also where can I buy the belt for inexpensive price?
Nowhere really, vbeltguys has a good price per belt but $7 shipping
260mm to 285mm should be fine
actually aliexpess.
can get 10 good belts for around 28$
Just gotta put belt sizes in the search bar in this format.
275-5M-15
^first section is belt lenght, second section is belt type (HDT-5M), Thrid section is belt width.
