Hello eSk8 builders!
I’m creating the diagram for a 6s2p with BMS (only for charging the board) and I am mess with the wiring diagram.
I made this one but is incorrect because the power for the motor go trough the BMS and this one can not support that amps:
I think is correct but I will love to share it with you to have second and third opinions and be totally sure that I have to connect it that way (yes, maybe I’m freaking out with the wiring but I dont want anything to explode haha)
That is my first doubt, the second I have is… How can I connect the balance cable
Hello @wmj259 I really dont know that, one electric skate builder sent me that image but if you have corrections be free to share it, it will be very very helpful because I’m blocked with the wiring
I hope this will make it more clear, you don’t need to look at the colors because they can always be different.
This is a 4S balance cable and a 6S balance cable with both different color wires
I’m just using a weld from weller.
Add some flux on the battery connectors so it will weld much better and then just heat the wires long enough because they are very thick and then just add your tin (or how is it called in english )
