Finally almost have my first battery figured out… I’m will fit a 10s4p in an enclosure I made for a jet spud deck…
I still have to solder 8 positive to 9 negative with the black wire 9 positive to 9 positive with the red wire to complete group 9, then spot weld the top two 9 positive’s to the bottom two 10 negatives with the nickel strip, and 10 negative to 10 negative with the black wire to complete group 10
Hope this made sense
I’m going to be wrapping group 9 and group 10 separate with kapton tape
This may seem like an dumb question but again this is my first battery build ever and my brain is kinda fried and its late but I’d like to spot weld the top two 9 positive’s to the bottom two 10 negatives with the nickel strip so I can then solder on top of that… also on groups 1 through 8 I have 4 connections with nickel strip going from the negative to positive… and on group 9 and 10 I only will have two… that should be fine right? I hope that makes sense too…
