What specifications does an On/Off switch need to be usable in an electric skateboard? for instance: I will use 2x 3s 5000mAh 20c zippy’s and a motor which can draw at peak 60Amps
If this switch does not work, can you suggest a something to turn the board on and off? (disconnect the batteries) Thank you!
