I also tend more to 14s. But i love top speed to. 50mph is no problem with a normal downhill longboard. With full protective equipment, of course.
so i want top speed too. but what I have never experienced before, a skateboard that has so much acceleration that I can barely stand on it. I want that
With 200mm wheels it schould be 400n. I wonder if 400n is enough to not be able to stand on it if you lean forward as far as possible. For a 95 kg Rider.
I hope my calculation is correct. does anyone know how fast it will make 100m?
Just make sure you got some real good gloves and I’ll assume you already have an elite full face helmet.
falling off an esk8 is different to downhill
you drive in streets and in new areas 24/7.
and the board itself can stop go glitch cog jam stop at the worst of times any little hick up can send you flying or wobbling (I’m not saying glitching happend to me) but you still gotta take that into consideration especially because at your higher speeds (and power) tolerances are much much lower.
I meant suggestions for a suitable deck. But thanks for your reminder of safety.
I want to build 16s6p battery now. I only ever see people who first build 6p packs and then build them in 16s. But I would have to do it the other way around. Is that how it works? or is there any problem if I first build six 16s and then combine them to 6p.
