The bigger wheels will make a big difference by themselves. I wasn’t sure about this either I also have a smaller board with a kick tail so going too big is out of the question unless I change boards again. I went with some ultra cheap 90mm ones I found on Amazon:
I figure for the price if they decompose in 6 months or something it’s not really a problem (no-name brand as far as I know).
I went from some 83mm to these and seems a big improvement in ride quality on crappy roads or when going over gravel. If you had lots of gravel roads not just some construction then you need pneumatics I think but the bigger diameter itself will make a difference. One thing to beware of is you’re going to have the wheel closer to the motor pulley now and there is less clearance between the board and wheels so if you don’t already have some .5" risers or bigger that’s probably a good idea to avoid any wheel bite when you lean hard.
i hav 97mm 80a clone as well. not this cheap but it holds really well. it did chipd but nothing major.
I assume mine is not actually 80a but higher cuz it is really hard close to 85a i think.
thanks for suggestion let me know how it works!
it’s just too flexy. You need a stiff board for high speed.
You never see downhillers using bamboo decks.
Then again, I can’t imagine doing high speed on such rough roads anyway.
Maybe in your case, a bamboo deck and soft wheels and just keep your speed under 20mph
Clones are not as soft as genuine Abec11’s
I was worries about that myself when I first got my 6 shooters, and I still live em, but Thane is too much fun to abandon. So I built yet another deck .
Mbs 100mm wheels are only good if it’s dry there is less contact where as abec flywheels have more contact with the ground and I find them better in rough ground and then there’s the price abec 97 are 100 e or so and mbs are 65 e I have a set of each and like them abec for damp weather and mbs for the dry
and this makes it def smoother. but I can still feel the cracks. it may get better as wear in.
is it worth 120? kinda. its more gippy so turns better give u more control.
the color still the worst part
Hahaha, thumbs up for that comment. That’s the only reason keeping me from purchase. Well green is OK-ish but with orange? Bleh. Shame because there is no alternative but they are genuinely good (best, really).
Don’t underestimate shoes! I’ve been wearing Nike SB’s and like vans and other skate shoes the vibration from rough roads is enough to make your feet go numb after a long ride. Now I’ve started to use some Nike running shoes with a thick foam sole. It absorbs so much vibration it make the board feel like a cloud, another plus is the mesh top that lets air in as you ride, cooling your feet. The only downside I see is the lack of abrasion protection.
