Dear viewers, I really, really, REALLY messed up and need some advice… A while ago (first test ride of my first board) I was using a cheap mount and it came loose and started dragging. The dragging bumped up my Ollin OM5065 motor and put a lot of sharp ugly scratches on it. Basically what I did was put sand paper over it and spun the motor so I can repaint it.
Disassemble the motor, remove the can, prime and paint. I would suggest a high temp epoxy, something for an engine block would be perfect. Or you could just slap some vinyl on it.
It’ll look fine for a bit, but vinyl wont stand up to road trash as well as paint will. Honestly, I would just ride it. You will likely upgrade to a 63mm motor before its over anyways.
