So i built a board a month or s ago and then i got some major upgrades (like a bms) and put them on last weekend. I realized i didn’t have a charger with enough voltage to charge my batteries. So i bough this charger here off amazon:
I chopped off the connector it came with and put an xt60 connector to the cord. My issue is that when i plug it in, it progressively charges slower, but when i go to ride it after my indicator says a decent percent (around 50%), i barely made it around my block which is about 0.4 miles (0.7 km) and then it just completely died. Maybe i wired the BMS incorrectly or i need a charger like this:
Charging lithium ion batteries can be split into two main stages:
Constant current charge: In the first stage of charging a li-ion battery or cell, the charge current is controlled. Typically this will be between 0.5 and 1.0 C. (NB: for a 2 000 mAh battery the charge rate would be 2 000 mA for a charge rate of C). For consumer based LCO cells and batteries, a charge rate of a maximum of 0.8C is recommended.
During this stage the voltage across the lithium ion cell increases for the constant current charge. The charge time may be around an hour for this stage.
Saturation charge: After a time the voltage peaks at 4.2 Volts for an LCO cell. At this point the cell or battery must enter a second stage of charging known as the saturation charge. A constant voltage of 4.2 volts is maintained and the current will steadily fall. The end of the charge cycle is reached when the current falls to around 10% of the rated current. The charge time may be around two hours for this stage dependent upon the type of cell and the manufacturer, etc…
What happened is you got to the end of the first stage, but never entered the second stage, because that charger can’t do the second phase, only the first.
You can charge the batterys also with a normal power supply. As long as it doesn’t exceed the voltage of 4.2 a cell it will be fine. The 2 phases happen automatically when the power supply doesn’t exceed the voltage. So in the first phase it will be regulated by the current (voltage is lower than 4.2V a cell) and when it reached 4.2V a cell the current will decrease automatically because higher current can only be achieved with higher voltage.
Guess the issue with the power supply of mgertner is that when it can’t achieve 32V it shuts down or something like that.
