I think the Unity is the problem, they changed the original VESC Firmware quite a bit which might break compatibility with those libraries. Actually I did the same thing yesterday
https://forum./t/grunstern-mov-e-shortboard-12s3p-nese-hummie-hubs-hammock-baseplates/2409/153
But with a FSESC 6.6 dual which is a “classic” VESC.
I will try your code this afternoon, but if is a classic VESC, I think that the problem will persist.
I found another library for Focbox. I will try it too.
I can’t undestand that if they modify the firmware of vesc, dont create a library or something to use the UART port. I think that without that this port in a little bit unuseful.
What is then its purpose? Only bluetooth controller?
Mhh, Stefans version is a fork of solidgeeks library where the PPM stuff is missing, but it should be easily doable to apply Stefans changes to @Pimousse fork I have no unity and therefore no need
When you do please share it again so someone can easily do this in the future. Its quite easy with the normal VESC.
