I have all my parts, not sure where to actually start building, never done one before. I was just going to copy a youtube video?
Are there any step by step by guides on the forum?
I was going to
attack trucks
assemble motor mount (not sure all the steps for doing this)
line up everything else for enclosure assembly
waterproof bms / vesc
install battery and connect everything and drill in enclosure
I dont take any particular order i just do what i can with the time i have for the day. Id say start simple with the deck trucks and motors and pullies then do the electeonics.
6374 single motor
caliber 2 trucks
100mm flywheel clones
all the parts for a drive train
bms
acryllic for waterproofing
kydex sheet for enclosure
and stuff to make the battery, which I will deal with later I want to assemble the mechanical parts first
All of them that don’t have nyloc nuts. Every one. Including the grub screws on the motor pullies and everything. But only after a test ride. And stop multiple times during the ride to make sure bolts aren’t backing-out.
Set up your mechanical parts to where you can stand on the board with wheels to note where possible bite might occur. Lay electronics out and make sure you’re set on everything before finalizing connections and enclosure
