what do you use to hold your electrics and stuff to the deck if using foam on the deck for anti vibration ?
If you’re using plastic enclosures
Build onto the deck with dual lock Velcro
If you’re using fiberglass or composite enclosures
build into the enclosure, I typically silicone things in.
or do the best of both worlds, silicone to the deck.
wont have the deck or enclosure long tho as iv a hyperbest coming… hmmm
I use 2 layers 3m dual stick foam tape, you get best of both worlds
My decks wood. my encounters wood so I glued them together then also used 4 L-brackets for extra strength. I then screwed my esc down and use straps for the LiPos.
i use this, one side on the components, then the other on the deck
then use foam between components and enclosure to keep stuff from vibrating
https://www.amazon.com/90197-Industrial-Strength-Sticky-Back-Fasteners/dp/B00006RSP1
