Hi, guys, I am wondering how many km/miles my board will last. If anyone knows a website calculator (like calc.esk8.it) to find the distance. or even just know from experience
Planned specs:
Motor: Turnigy 280kv
Battery: (2x 3s 5000mah lipo)
Wheels: 59mm
Belt: 3:1 ratio
ESC: 120a x-car beast series
(I’m not sure if anything else will affect the distance if you need more info please just comment)
Well for one thing, you would need 4 of those 3s 5000mah batteries to get 6s 10000mah. To answer your question, it would be 3.7610 to get watt-hours like, then divide that by 10, because most setups use around 10 watt-hours per km.
Nope. When you add cells together, you either get more volts, or more mAh, not both. I’ve built my own battery packs, I know my way around volts amps and watts.
You need at least 6S and with 2x 3S 5Ah in series you’ll have a 6S 5Ah and you’ll get about 4-6 Mile’s of range depending on how fast you go. I have a 6S 10Ah pack which is made up of 4x 3S 5Ah Zippy Compact packs and I get about 10-14 miles of range.
