Lots of variables to consider that you didn’t include, but that battery is small (7ah) and weak (30A max discharge) so it will probably disappoint you.
That’s about the cheapest 10S3P 30Q you can find. It’s twice as powerful, and offers ~30% more range by specs. It’s a proven cell, the 30Q, so probably even better. Though mboards doesn’t build the nicest packs, it comes w/ a charger, so packs from elsewhere will be ~$50 more.
This is what I would get if I was you, looking for something to add to my cart.
+ a charger.
Depending on your size constraints, you could also check out the Meepo ER battery. It’s significantly smaller for a small decrease in charge and current output. I would say it can supply more than the 30 A listed on their website since it uses the 40T batteries which should enable twice that.
