That sounds like a pretty good option. How much capacity could you get me with a 10s voltage and less than 2 inches? Also, with a BMS does that mean I don’t need a balance charger?
I’ll have to do some research I’ll pm you
@PLEB You might want to check out this thread on making flat packs from regular lipo packs.
Courtesy of @barajabaliThought I’d give the public an update on this battery I’m building for @PLEB s deck.
Going with lipo to get the most we can possibly get from the space given. These cells are less then 2 inches wide which will fit perfectly and the pack will be about 15 inches long at 10s1p 37v 8ah It will feature BMS with charger Soft switch Percentage display
(Possibly an enclosure)
