I want to calculate the range that I will get( Thanks a lot, Ron
You need: Your weight + the board Battery watt hours Motor efficiency Any hills
http://calc.esk8.today/ <-- this site will help you. Roughly speaking 10Wh=1km but all the variables matter as well as what you consider âsafeâ cut off voltage.
I run 185Wh (2 5Ah 5S in series to make 10S 5Ah) and get about 20km (12 miles) on flat ground (Chicago) and being a light dude (around 120lbs) before my batteries are down to around 3.5V per cell (LiPo)
totally depends on setup and weight.
i get about 13km with 10S3P about 280Wh i weigh 200 pounds.
Not just that itâs how you ride too there is a big range different when Iâm hauling ass and when Iâm cruising.
I get 18-20miles range riding fast and hard. I get 27-30miles just derping around.
Yup agree ride style+weight+elevation changes all make a difference (not to mention electrical efficiency/losses between/within components)
I found messing with the gear ratio < 2 restricts range/life
esk8 range calc says with 10S3P 288Wh with dual drive 30wh/km i get 15.8km.
i get 13-14 think thats pretty accurate
30Wh/km?? What the hack kind of riding are you doing? 0-50-0 all the time??
Lmao yea right, my Raptor 1 is Dual 6355 with a very Old 10s3p it doesnât charge to 100% anymore and I still get 10+ miles out of it
I live in baltimore city and do a lot of 0-max a lot. It it is a blast but kills battery life.
Thank you every one! That helped me a lot
Thats per mile, or 1.6km! Seems alot off thought, especially at the higher numbers.
Like, Who the fuck uses 80Wh/mile? Even on 4wd Thats too extreme, unless offroad maybeâŚ
true yeah, but i still just reach around 13-14km
My Evo, 13s5pâŚ
With a cutoff of 3.35/cell, leaves approximately 35-40% charge left in my cells.
My pack is 709Wh calculated at 3.6v nominal.
I can pull 43/44 miles out before the âcuttoffâ which still leaves me at 3.38/cell without the sag.
When I charge, it puts in about 440-460Wh back into the pack, meaning I discharge to about 37%
Letâs take the median 450Wh used / 44 miles = ~10.22 Wh/mile.
Or, thatâs how I see it on my Evo
Whuuuut.? Thats incredible efficiency!
Two questions⌠what are your battery cutoff limits? What is your riding style, run and gun, or cruising?
57v max(full charge is 54.6v) 44v cutoff start, 43v cutoff end
I ride like a bat out of hell, I am a speed junkie. I ride street, and regularly keep up with traffic. Lots of run and gun on the street, moderate cruising
That is what I assumed. I love keeping up with traffic, otherwise there is no point. I havenât run my battery to its end, but based on my last run in my new setup, I figure I will get about 20 miles. I have a 12s4p of 25r (I wish I paid extra and went with 30q). I am also just north of 200 so I know that impacts it as well.
