How to connect 3 batteries in series to make a 9S battery?
On hobbyking I see that there is a harness for connecting 2 batteries in series. I need to connect 3 in series to make a 9S battery but I can’t find a three battery harness on any site. Any other options? Could I somehow rig up a system by using several harnesses and cutting the extra wires?
Also, I found some tutorials on youtube on how to make a custom 3 battery harness that require a lot of soddering and drilling. If possible, I would like to use parts off of hobbyking or some other online supplier.
Thanks!
I’m trying to find this too, did you ever find the solution?
That’s not how series connections work.
If you’re trying to get away with something, you could try cutting and crimping.
