Hi guys,
Yesterday FOCBOX was exposed to water and 3 mosfets blew up. I replaced these with new ones and checked connection after soldering to make sure everything is okay MOSFET side.
Tried to run motor detection but failed, values are super high and not corresponding to the usual values of my motor, also the motor won’t rotate.
I think that the DRV might be fried as I’m pretty sure the MOSFETs gates were shorted with drain or source so 50V on the gate pin of the DRV seems quite bad to me…
The fault led flashes when I try to run detection.
But DRV doesn’t look bad.
Do you think I need to replace this one too?
So I checked on vesc tool, there is no faults when I do motor detection even though the detection fails…
The motor makes a high pitch sound when I try to run it.
The more I try things, the more I think the drv is fine. Even checked the gate votage regulator, shows 11V on C18/C26.
Do you think that could be a Mosfet problem? Any way to check these?
Thanks guys
