How to make your 3D printed remote/part look HELLA PRO!
Remotes, they’re as important if not more than the board itself. I personally go for aesthetics for my builds, so if the board looks sick, the remote must too. I’m currently getting into DIY remotes and unfortunately the casings are often 3D printed. Don’t get me wrong, 3D prints are great and some can produce prints with fine resolutions that would be good enough for most. I do not like the look of a 3D print so i have a few methods of smoothing out a 3D print to look like an injection molded piece or even better!
https://www.amazon.com/XTC-3D-High-Performance-Print-Coating/dp/B01BKSLI9M/ref=sr_1_2?s=sporting-goods&ie=UTF8&qid=1533491772&sr=8-2&keywords=xtc3d
This is XTC-3D. It’s essentially a resin that is two parts, you mix the resin with the hardener at a 2:1 ratio and then brush it onto your print. It self levels so it will fill the lines and eliminate the ‘staircase’ effect that is caused by the printer.
20180523_20302020180523_214523
I got a Photon remote months back, the print was very fine actually, but i went ahead and smoothed it even further. 20180522_215814
This is just from one coat! 20180523_234002
I sanded the first coat and applied a couple more to fill up the words. Sorry @Wajdi :joy: 20180524_143028
And there it is! You coooooould leave it like this can call it done, or use a scotch brite pad and make a matte finish as you see fit.20180525_101737
Hello there Plasti Dip
https://www.amazon.com/PERFORMIX-11221-Multi-Purpose-Coating-Aerosol/dp/B008J20R1S/ref=sr_1_2?s=hi&ie=UTF8&qid=1533493501&sr=1-2&keywords=plastidip 20180617_142422
Plastidip is a rubber spray, usually used on flexible materials or on surfaces that need traction. This works great for remotes as it’ll prevent slippage from the hand.
My method of spraying is one light coat, then a normal coat to get the surface wet, and the third and final coat is sprayed from about 2 feet/60cm away to get this ‘orange peel’ effect on the surface. Wait 30 mins per coat. 20180617_002621
Here’s some more pics of the surface. Oh! If you do this, spray a coat of primer first, and lightly sand the primer a bit, it’ll give the Plastidip something to grip on. 20180617_13583220180617_12532820180617_12525320180617_12532420180617_135839
But Lin! I don’t wanna spend 20 bucks on resin! No worries, there’s another method.
Acetone Vapor bath IiI5nKH I ripped this picture from the net because i myself have not tried this. But i have seen some incredible results from others.
Acetone is a solvent that is often used to clean oil from parts and also melts plastic materials and styrofoam, and a few others that i can’t remember from the back of my head. Do note that if you’re doing this to your print, ONLY ABS WILL WORK.
Doing this with PLA will cause it to be very brittle and will snap rather easily. Not sure about other filaments like PETG or Nylon but do feel free to experiment if you have some acetone lying around. Do not try to brush Acetone on your ABS print as well as the surface when it dries will usually be worst than before. Hence the Acetone Bath method. It’s a more controllable way to let the vapors wrap around the print and circulate, causing the print to slowly melt from the surface and fuse.
The pros of this is that your print will be 100% solid and stronger as the print lines are fused and becomes a single piece, with no risk of delamination.
I’ll link a video on how it works down below, using a cheap method with a glass cup and a paper towel with some acetone absorbed.
https://www.youtube.com/watch?v=yyoefQ4k4BA
https://www.youtube.com/watch?v=6xFUNFG-UKE
So if you’re doing a larger piece, use a bigger container that is not ABS and hope for the best! Do leave your print to dry overnight prefably after removing the print from the bath so it’ll dry fully.
Filler Primer
https://www.amazon.com/Rust-Oleum-249279-Automotive-11-Ounce-Filler/dp/B003CT4AM0/ref=sr_1_2?s=hi&ie=UTF8&qid=1533491914&sr=1-2&keywords=rustoleum+filler+primer
It’s a primer spray that fills up the 3D print lines, less mess than the XTC- 3D. I didn’t do this for another remote but i did use this for a little project i did three years ago. I made an Iron Man suit and got the fingers 3D printed. The rest of the suit was made of cardboard and then fiberglassed.
Taped the 3D printed fingers to my cardboard tray…
1
Sprayed three or four coats, wet sand with 400 grit to even out the layers if needed 2
Nice and smooth. 3
Spray a few coats of your desired paint45 But yea, the method is the same if you were to do that on your remote or belt cover etc.
Now, if you want to change the shape of the remote and give it some bulk for example, then you will have to use this.
Automotive body filler/Bondo
https://www.amazon.com/Bondo-312-Autobody-Filler-Quart/dp/B0007ZE7XY/ref=sr_1_4?s=hi&ie=UTF8&qid=1533492363&sr=1-4&keywords=bondo
This is a body filler, usually used to fix car dents. This is not recommended if your remote has a complex shape like the GT2B, you will have a lot of sanding to do.
How does it work? It has the body filler which comes in a cake icing consistency, and a tube of hardener. The usual mixing ratio is 98:2, yea i know it’s weird. But i usually mix a golf ball size, and two drops of hardener. So if you’re mixing less, then divide accordingly.
Commonly asked questions, Does more hardener make the filler stronger? No, it’ll just make the filler cure faster, which is not good because you will have lesser time to work with it.
Can i use the body filler without the hardener? No, it’ll never cure/dry and will remain sticky and yucky. I’ll link a video to how the body filler works, and how to apply it. In the video he’s applying it to a car part, so if you’re applying it to a small item like a remote, i recommend using popsicle sticks or poker cards.
https://www.youtube.com/watch?v=fRPEDZ7Q3vM
I did this method for a DIY remote @ervinelin made, as the model’s edges were a chamfer, and i wanted a round edge throughout, so off i went.
I sanded the surfaces with a rough grit before applying, so the body filler has something to grip on.
20180618_185008
Here’s a tip, PLEASE work in one section at a time and use small amounts. Once it starts to harden, which is usually around 2 mins, it’ll gum up and won’t be like a cream anymore. The piece above started to harden, as i was working too slow, and it balled up and the surface was bad. Nothing a little sanding can’t fix, but it’s extra work. 20180618_190211
Kinda look like chicken legs.20180618_204956
After some sanding. Note that you won’t be able to get it done with just one coat. You have to sand each coat, and then fill up any imperfections with more filler. 20180619_002815
After three coats, sanding in between and got it nice and round. 20180619_002830
In comparison with the 3D print20180619_00284220180619_002911
After that, spray a couple coats of primer and choose your color of choice and call it done! I went with the Plastidip method after that and it looks really good. I chose Plastidip because it has a rubbery feel and won’t slip off your hand easily. 20180619_235350
20180619_234955
20180619_235357
So yea, these are the methods i use to turn a 3D print to a professional looking piece. If you guys have any other methods, do share with us as well!
Awesome definitely been looking for this kinda stuff. I’ve been very tempted to try some sugru out for the same kinda idea but I lack access to a 3d printer.
That’s huge, thank you for the step-o-step!
Wrapping Sugru around a remote? That’s gonna cost a few packs haha. I’d say spraying Plastidip would be easier and have a more uniform surface.
Wow! this must be the sexiest Photon remote I have seen so far, good job and well written tutorial!
A sexy remote has to be given a sexy surface. Once the new receiver comes i’ll use this for my dual drive!
thanx for the detailed explanation.
Was also looking at xtc-3d as a solution for smoothing the surface.
You’re welcome! Do post it here if you’re gonna attempt, interested to see how it goes.
Great guide! My prints not always that perfect and I was looking for options to give them a nice finish. All I need in your thread :+1:
Damn. Noice skills bud. You do commission work? Lol There’s a 3D printer at the library down the street from my house I’ve been meaning to use. I just bought a benchwheel Wheel remote but I’ve been kind of wanting to do a DIY. Or at least a custom shell.
I used to do commission work for costume props back in the day, but now i just do em for fun. I’d recommend giving any of these methods a try yourself. The knowledge and skill gained is priceless :stuck_out_tongue_winking_eye:
I want something odd made lol.
Drop me a PM and we’ll work something out! Hopefully it’s not too complex/big of an item cus i’m getting a bit busy this period :sweat_smile:
Nice! You should add the aceton ABS method aswell. Cheap and effective
Good idea! That slipped my mind haha
Updated! I’ve never succeeded doing the Acetone bath before because the last time i tried it, that was four years ago. Then i never came back to try it again in fear of messing it up again.
awesome work and instructions @linny now it’s time for you to dabble into hydro dipping. I’m sure there would be a lot of use who wants to use that to personalize remotes, helment and even decks!
^^^^ this. So much this
Bad Ass! Nice post :slight_smile:
Great guide, thanks, will definitely try some of it
I did acetone bath a few times, the big problem is to know when to take it out, if you leave it too long the acetone begin to dissolve the whole print and it can loose shape
Also give a try to MEK, from my experience some ABS compositions don’t dissolve enough with pure acetone, MEK is way stronger, also great to make a slurry and use it to glue parts
