soooo… I have 2 4s lipos wired in series that I’m planning to wire to a bms. I already have the bms (bought a complete setup 190kv, battery, vesc and all that came with a bms). I don’t know what bms it is but I’ll figure out the wiring, there’s plenty of topics about that. I found a battery charger on ebay: it’s 33,6V for li-po’ and li-ion: is this the one I’m looking for? I don’t want to burn my house down
Yep that’s the right charger, Just make sure you’ve wired the charge and discharge correctly. Then you won’t burn your house down.
Thanks man! luckily the charger has polarity written on it (+in -out). now I’ll just read a metric fuckton of threads to be sure to wire the cells correctly to the bms.
Boy, lithium is scary
At first it really is, and don’t worry, i’m pretty sure everyone here started with nothing too, just keep reading up my friend!!
I know, right? I’ve read everything on this forum concerning battery management systems and still fear to fuck up big time When the charger will arrive I’ll man up and do the thing triple checking everything so I don’t blow up my flat. usually I’m ok with mechanics and light electronic jobs, but I’ve never done anything concerning potential lithium bombs. I’ll be prepared for worst scenario while praying that everything goes flawlessly!
https://www.icharger.co.nz/icharger-308-duo
this is what I use
keep that attitude dude, always triple check every thing…
$275 is about $225 too much for an 8S charger. That’s a balance charger for use with no BMS…
wow that’s expensive!
btw I discovered that my bms is one from hobbyking and has an output of 10A max, so I’ll have to bypass it in discharge. is this potentially dangerous? I have vesc cutoff setup to 3.6V so I’m not likely to over discharge but I don’t want to damage my batteries
It should be okay if everything is done correctly.
I plan to have two discrete circuits: one with antispark led switch going from the battery to the vesc, with an inline battery meter that switches on with the board. The second one is the charge circuit: battery and balance leads to the bms. It’s not clear to me if I’ve to have a switch on the second circuit or if it’s useless to have it. Am I totally wrong here?
You’re correct. Just hook up the BMS and charger jack with all 22AWG wire
Then directly to the battery, around the BMS, using 10AWG connect either a loop_key OR an antispark switch and the ESC(s)
thank you so much!
So a switch for the charging circuit is not needed? I wonder if the bms could slowly bleed the battery? This is the easiest part of the job.
Now I’ll have to get a female dc jack, 22awg wires and a 2 4s to 1 8s adapter, so I can leave the batteries as they are without cutting and resoldering the balance harnesses.
The BMS will switch the charge jack off automatically. The charger will switch the charge off automatically. This is redundant safety so if either one fails hopefully fire is averted.
Make sure the charge jack negative wire goes through the BMS connected to C- (or P- if there is no C-)
so… I finally received all the parts I needed and the charger for my setup.
I searched the scheme for my bms and I connected the charging jack to p- and to the positive lead for my battery and the negative lead from the battery to b-. I’ve now to wire up the balance wires to the adapter that was included with the bms, but the batteries have 10 wires coming out and the adapter only has 9.
to my understanding I have to start counting cells from the negative side of the battery (the one that has the black wire going to the bms’s b-) and wire sequentially starting to the black balance wire to b-, b1,2 and so on, and on b4 I’ve to join the red balance wire from the first battery with the black one from the second battery. just not to screw up anything I want to be extra sure of what I’m doing here, cause I’ve not found a suitable example of this searching online
I’ll give all my appreciation to whoever is going to tell me if I’m going to start a big fire or not!
What does it say under the small black wire in the top of the photo?
Before you plug the white connector into the BMS you want to check with a multimeter that –
From the big B- wire to
small B- is 0V small B1 is 4V small B2 is 8V small B3 is 12V …
Of course it may not be exactly 4V, it could be 2.8V to 4.2V but it should go up progressively in that manner. If that’s not the case, don’t plug it in yet.
Always only work on one wire at a time to avoid short circuits and fires. Insulate each connection before starting another one.
yep, that’s the plan but I’ve yet to figure out what to do with the 10 cables going to be 9 thing going this way I should encounter one wire from the battery that gives me the same voltage of the one before it. I don’t understand if I have to cut and insulate this wire or if I have to join it with the previous one that should be b4
What battery? Do you have a photo without the BMS covering the labels?
every battery has 5 wires for balancing, so battery 1(the negative side) goes from b- to b4 and the other one follows from b5 to b8, but having 5 balancing wires each one wire is going to be left out or connected to another.
batteries are multistar 4s 5200 (Bad I know, but these are not definitive)
