Hi, I bought a cheap 72mm Hubmotor on Bangood or Gerarbest for something like 30$ inkl. shipping.
After a successful motor recognition on FOC/Sensorless and completing the VESC Tool setup I got out to test it on the road. Everything was working fine till I hit the brakes for the first time. After hearing some weird noises the motor wouldn’t spin un anymore.
Today I’ve taken it apart to see what the reason for the motor failure could be .
I’ve noticed that the motor wiring seems a bit odd for a normal BLDC motor (See the pictures below):
Can someone with some BLDC-motor knowledge @Hummie@evoheyax help me figure out the problem?
Thank you
After the incident I flashed the vesc and got stuck at the Motor recognition (FOC). Tomorrow I could try BLDC and see what happens. I’ll report the results.
Try running the Vesc again if there is any faults it should happen again and then you will be able to use the terminal thing to find the fault codes. Idk if that will work but it makes sense that it would
