Do the detection again until it errors out. Then go to terminal and type ‘faults’. Paste any faults here.
I was helping someone else recently with a failed detection. It faulted with an ABS_Over_current fault. We concluded it was a bad VESC given that detection on the same motor worked on another VESC with the same power source.
I typed in “faults” and a lot of things came up and the motor is still not responding. what else am i supposed to do?this is what came up when I typed faults-
Hi mate. I see your motor has 3 black wires. How do you know which wire is which? I have this problem with my alien drive motor. It has 3 black wires and i have no idea which to connect where? thanks
Hi. As i see, you motor has 3 black wires. how do you know which one is which? i have this problem. i have alien power systems motor and it has 3 black wires. and i have no idea which one to connect where? can you help please? thnks
If the wires are well insulated (you don’t see bare copper) you can proceed connecting them randomly. Power them. If the spinning direction is wrong, just swap 2 cables.
Please use search function next time: faster for you, less spam for the forum.
thanks for such fast reply. i did use search function and tried many different key word combination but was not able to find anything. so i can randomly connect those 3 wires and it will not damage neither my motor nor vesc? and just play around untill i find correct connection?
Hello,
About a 2 months ago I bought two Maytche VESCs from Alien power system and as I finished setting everything up and assembling everything I plugged it all in but when I turned my Enertion pace cell pro 3 the controller connected to the receiver which was getting power but I realized the VESC’s where not responding so I disconnected everything and attempted to connect them to my computer. But I realized that when I plug the plug the battery in, nothing happened and the VESC’s does not light up. But the receiver gets power when I connect it to the VESC’s and the micro USB ports on the VESC’s do get really hot in about 10 seconds.
