Hey everybody, I hope you’re all well!
I’m onto my second Vanguard build, finally using 10S!
I’ve received my enclosures from @Eboosted - thanks Alan! ![:smiley: :smiley:](https://electric-skateboard.builders/images/emoji/twitter/smiley.png?v=9)
Focboxes and other parts from @okp / UNIK
Basically I’d love anybody’s thoughts on how to mount 2x Focbox, while being mindful of heat dissipation. I did think about mounting them on a thin plate, with ‘fins’ coming out each side of the enclosure, very much like how Boosted have done on their ESC enclosure. Very low-profile fins, though (I have a friend who is a tool-maker and has access to CNC machines). Of course, there needs to be space for the parallel connector to power the Focboxes as well as the other wiring.
![Dual-Focbox-Eboosted-Enclosure](https://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/original/3X/3/8/3838c837e1bf4dcd1d87d0e7904992eade5a2b5b.jpg)
Any ideas and suggestions are much appreciated!
Thanks,
Jonny.
Guessing your using a Vanguard or similar flexy deck?
While I myself am not assembling my own (thank you @psychotiller
), there are a few threads with implementations one here’s one by EBoosted himself:
Thread
Edit: saw this post was Focbox specific
, I’m sure one of these vanguard threads have one , try searching for EBoosted Vanguard Encolsures and one of the Build threads that refer to it must have a photo of implementation
Might be helpful, don’t think it’s got a heat sink though
Yes, this will be my 2nd Vanguard build, I wrote a little about that in the first post. Thanks for that link! I saw it previously but I don’t think Alan had added photos of inside the ESC enclosure.
VERY helpful, thanks @pat.speed ![:smiley: :smiley:](https://electric-skateboard.builders/images/emoji/twitter/smiley.png?v=9)
I wouldn’t mind about heat dissipation on the vamguard 10s4p, it works flawlessly without a jheatsink unless you live in a hilly area and weight 120kg and beat the sh!t out of the motors ![:smile: :smile:](https://electric-skateboard.builders/images/emoji/twitter/smile.png?v=9)
Thanks Alan! For some reason I had the idea in my head that I’d have to manage heat! Probably because I’m used to 6S and a 5065 motor - it runs very hot sometimes!
Don’t worry, it works pretty well with no heat sink. If you even encounter a heat rising issue consider a heat sink, in the meanwhile just run it as it is.
Thanks for the advice Alan ![:slight_smile: :slight_smile:](https://electric-skateboard.builders/images/emoji/twitter/slight_smile.png?v=9)
