E-boarding is an expensive hobby, and frankly that money spent on parts can and should be used elsewhere in my case. I have mounts, batteries, enclosures, controllers, pulleys, belts, etc. (new and used). I’ll have a proper list with pricing and pictures later. (CONT. US ONLY)
Sad to see you go! You will be missed. I’ll definitely try to grab something from your sale!
It’s a sad day…
Hope you hit the lottery or some shit so you come back to it
Hit me up, maybe I’ll buy the entire lot pick up
Once the board is built and paid for , what other costs are there??
That sucks, but this hobby can definitely turn into a bottomless money pit. Hope you can eventually come back at some point and at least have a budget build to ride for fun.
hmu bout a mount
2 x Multistar High Capacity 4S 10000mAh Multi-Rotor Lipo Pack (Practically New. One has an XT-90 connector while the other has no connector, just electrical tape and heatstrink) $ 80 for both SOLD
2 x Turnigy 7200mAh 4S 14.8V 40C Hardcase Pack $60 for both SOLD
2 x Tacon Big Foot 160 Brushless Out Runner Motor (Both have 5.5mm bullet connectors. I tried to modify one with flexible silicon wire, but cut to close to the can. May need to be redone. $80 for both SOLD
1 x TorqueBoards 2.4Ghz Mini Remote Controller (New) $35 SOLD
1 x Wiiceiver and Wii Kama Wireless Nunchuck $30 SOLD
2 x DIY 16T HTD5 Motor Pulley 9mm (New) both for $20 SOLD
2 x DIY 12T HTD5 Motor Pulley 9mm (New) both for $20 SOLD
1 x Enertion Motor Mount, Wheel Pulley, and 14T HTD5 Motor Pulley 9mm (grub screws missing from mount, can’t find other 5 bolts for wheel pulley, doesn’t come with wheel plate) $60 SOLD
1 x Enertion 12mm Wide Drive Pulley Kit (New) $30 SOLD
4 x 255T HTD5 9mm Belts (New) $15 for all. SOLD
1 x Flywheel Clones Green 90mm (Never been ridden) $15 SOLD
1 x Enertion PowerWheels 83mm (Used) $10 *buy both the flywheel clones and the enertion wheels for $20 SOLD
2 x DIY 36T ABEC11 Drive Wheel Pulley Kit 9mm (Slightly used) $25 each or $40 for both SOLD
1 x Psycotiller Pycho60 Motor Mount (60mm center to center) $30 SOLD
1 x Psycotiller Pycho66 Motor Mount (66mm center to center) $30 SOLD
1 x Turnigy 100A 60V Multi Function Watt Meter w/Temp Sensor (comes with xt90 connectors) $15 SOLD
2 x Psychotiller Custom enclosures 5.25" x 6" x 2" and 5.25" x 9" x 2" ID (Untrimmed) both for $50 SOLD
1 x Enertion R-Spec 2.0 6372 Big Boy (New) $125 SOLD
Check out what I have listed and see if it’s worth it for you to buy the entire lot.
interested in the tacons. What did you do with the tacon wires exactly again?
I’ll pick up any 12mm Enertion wheel pulleys from you if they’re still available.
Lol
He fucked them up
Lol
Everything is SOLD except for the batteries and the controllers.
Mini remote SOLD
All I have left are the 2 Turnigy 7200mAh 4S 14.8V 40C Hardcase Lipos. Can do both for $50.
