I just finished building my very first electric longboard. But, when i went to program my esc using the usb link it wouldn’t read the esc settings, and when i tried sending settings to the esc it wouldn’t change anything.
open the program on your pc
insert usb cable -> “USB DEVICE” should go green
make sure your esc has battery connected and motor (not turned on yet) Connect your usb cable to your ESC
Turn on your esc by connecting battery/loopkey/on off switch
both buttons should be Green now
yeah, i tried that like 50+ times
pressed enter to quick
If this didn’t work , you maybe need an extra Serial Usb program. But i’m not sure. It’s in the download links at alienpowersystem.com
they both turn green, i tried sending settings but no change, and when i read settings it stays blank
That is strange. You are using the correct program for your esc?
Well mine reads it automatically when I connect with my pc
ya, im pretty sure. i think it just cant be programed
