hey,
this is my firt build.
is ervery thing all right?
what should i do with the 2 negatives wires from the balance wire? nothing? or connect them to the ground?
do i need a anti spark switch?
is that the best switch location in that schematic?
can i use that charger 24V and 4Ah output for 6s lipo
here is my electronic part list.
2x motor 5055 190kv link
2x vesc link
bms 10A charge / 10A discharge link i want to bypass the bms
2 3s lipo 5Ah or 8Ah 5Ah8Ah
charger 24v and 4 Ah link
anti spark switch link
voltmeter link
why do i need more then 30A.
the voltmeter is parallel to the batteries. and the voltmeter has a high internal resistance. the greater the resistance, the lower the current is.
This is a power meter, it also measures the current flowing through it, so at >30 battery amps you’re going to melt it. How would it measure power with only the voltage?
is this one right? link
details:
No power supply required
Measuring voltage: DC 3.0-30V blue
Working current: <20mA
Display: Three-digit 0.4 \ "LED, blue color
Refresh speed: Approx.500mS / time
Highest input: DC 30V (higher than 30v has the risk of burning)
Minimum input: DC 3.0V (below 3.0V, measurement inaccurate or not show
Minimum resolution: 0.01 V (<10 V) /0.1V (> 10 V)
Resolution: 1% + 1 digit
Working temperature: -10 ℃ ~ 65 ℃
Size: about 40mm x 25mm x 23mm (L * B * H)
Mounting hole size: Approx.37 * 20mm
LED Color: Blue color
