So I have batteries with 5.5mm bullet connectors and I would connect 3 batteries in series from negative to positive. I get scared when doing this, so I’m wondering ?? Could I just cut the bullet connectors off and just solder some xt90. This way I could make a xt90 series connector to connect my batteries in series ??
yes. don’t fuck up polarities or cut wires at the same time.
Yes, just make sure you only leave one pole exposed at all times. And double check with the xt90 plug polarity which should be labeled on the sides.
What Pole ?
Pole as in positive or negative.
On the xt90 +/- labels does it matter if I put a positive one the + ? Because it seems impossible if that’s the case here ??? I know how to connect my batteries in series just by going negative to positive with battery {A} being the negative and battery {C} being the positive. This xt90 throwing me off
Side note: the cutter is my vesc
lol
I think you should put the connectors on the battery the right way first and then orientate the connectors on the harness so that it will work properly
They are dry set the right way. The harness in the picture I’m not using I just placed them there so I could have an idea. I would be making my own xt90 harness
The electrons don’t care. It could matter if, for example, you sold your board one day and someone else (or an older you) worked on it and got confused and made a lithium-polymer rocket by accident
Hell yea cool thank you
(Would keep that in mind in future if ever were to sell it)
Time to get to work
don’t EVER work on electronics on carpet
also, if you’re asking whether you need to solder + to + and - to - then yea, you do. otherwise you’ll plug it into the vesc and get some instant smoke
I’m making a harness so I’m confused how that’ll work. At work so I gotta see again once I get home
ahhhh you’re making a harness. sorry didn’t see that
so yea, in that case follow what everyone else said, just make sure it has your full attention. also, the last connector (one that connects to the vesc) MUST have the proper polarity. good luck!
You don’t need a series harness, nor do you need to cut off the connectors and use XT90s. The bullet connectors can be put directly in series. Plug A+ into B- and then B+ into C-
That’s what I’m doing now. But I like the idea of the harness because it seems safer
