Hi piople
I have a problem, help please.
I have ESC RacerStar 120A, two Li-Po 3s consistently to 6s, motor Turnigy SK3 63mm 245kv
Why is this happening?
Before that everything was fine, I used the same ESC.
Later I tried to use a new motor and a new battery and made a new wiring, but it happens the same way, it jerks and does not go.
Watch the video, what can it be?
https://www.youtube.com/watch?v=iI9vigr15Hc
This is what happens from a standstill with out sensors and hobby ECS’s. You will have to give a good push to alleviate this while riding.
it worked before, I could start from a place without repulsion
Hmm…Then your ESC might be toast.
as there was such problem, I bought a new ESC and it turns out the same way
Process of elimination: It may be your motor. Also, check to may sure none of your phase wires are exposed and touching each other.
I tried to use a new motor, it looks the same
bearings gone in your wheel?
Yes, the wheels are spinning.
I can also pinch the motor and it will twitch. Previously, this was not
Acido
May 8, 2018, 7:38pm
10
you probably fried the sensors with water or something
no, it’s a sensorless motor
Acido
May 8, 2018, 7:53pm
12
Open up the motor and check if you have a wire broken in any of your windings
Jinra
May 8, 2018, 7:57pm
13
give it a kick push and try accelerating, if it works then it’s because you don’t have sensors. This has been a thing for a LONG time. No sensors = no smooth loaded startup.
I had the same thing happen to me and it was the remote… it can happen
Did you redo the motor calibration in the vesc tool after changing up the wiring? Have heard this can make a difference and in my own build have seen that it is less twitchy on startup after I did a calibration.
is not VESC! this is car ESC
did not understand what was? how to fix?
if the motor is connected to the VESC and back connected to the ESC, can it become different?
