Hi guys
Lately I haven busy trying to set up a website to offer the eSk8 community complete boards and parts.
So far have the website is still a work in progress but I already have some item that will like for the community to see.
So to get started take a look at the motors
6355 230Kv
Input voltage ------------------------------6S - 12S
Sensors--------------------------------------120 deg.
Max Power Output -----------------------3200 Watts
Max input Rated Amps-------------------60 Amps
Shaft Diameter----------------------------- 8mm
Shaft length---------------------------------30mm
Shaft features -------------------------------3Ă—3 keyway slot.
And doble flat spot. 180Deg.
-Motor Wire: 240mm silicone 12AWG wire and 5.5mm Gold connectors.
-Sensor Wire: 300mm with 6 pin connector with JST-PH 2mm pitch, plug and play for the VESC.
Here some pics
In stock too is this other motor
6375 190Kv
Sensors ------------------------------------120deg
Max Power Output -----------------------3600 Watts
Max input Rated Amps------------------70 Amps
-Sensor Wire: regular rc.
Some pics.
Some other pic to compare
The price for the motors is as follows
6355 230Kv sensored --------- $ 85.00 6374 190Kv sensored ----------$ 100.00
Any inquiries feel free to PM me
